ok, so i printed out the coaster set, worked great, went back in and put it on there again only to realize there was not enough room on my plywood to cut it, i go to delete and it won’t let me do anything except add more artwork. sorry i’m a newbie, its definitely a learning curve for me.
If you select an item showing on the bed and then hit the delete button on your keyboard, it will be removed. If you do that on one of your own uploaded designs, you won’t be able to get it back unless you do an undo right afterwards. You would have to reload your original file. If it’s a catalog design, you can always get back to the original design by deleting everything in the bed view then going up to the “…” link in the menu and choosing Reset Design.
Thank you!
Thanks for the answer @cynd11, that’s right. I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
