I think I’ve spent too much time worrying about messing up a nice piece of wood. And I did, this time. Which is ok. I have stacks of wood now. Just need to start making.
Anyway, here’s this weekend’s box. It’s wenge and curly maple. Still haven’t put a finish on it. Testing a couple of things on failed parts to decide what I want.
thanks. i had good luck cutting it. and i measured kerf in a test, but i broke a few fingers putting the first piece together. this is some of that big wenge board that i had cut down a year ago and planed at that planing mill. the boards are slightly uneven, and i think that’s what caused it. so i think i need to over correct a tiny bit with the rest of it and just accept that i will probably have to glue.
^^ This I hoard material and covet the nice pieces so much so that I never use them. I look at them and think about what they could be, but then scrounge around for a lesser material when it comes to actual making because I’ll mourn losing the good stuff lol. Luckily for you using the good stuff worked out perfectly and it’s beautiful. I normally don’t like tab boxes becasue I find the seams too busy, but the dark edges work really nicely the pattern is a nice part of the design. Well done.
well… the final result looks that way. the broken piece doesn’t. and the half that i put one panel in backwards on doesn’t. sigh. but… hey… i like the final piece. and i need to get over the messed up pieces. making those mistakes helps me learn (and teaches me to focus a little more, too).
the box I made here is actually three partial boxes. the first two are the same box (although in this case I altered the flat edges to be opposite/match up curves). the third box is one that has exterior dimensions being ever so slightly (like a couple hundredths of an inch, IIRC) smaller than the interior dimensions of the second box. you can adjust height to be slightly taller if you want, but by default if it’s the same height as the original box, it will stick out the thickness of the bottom panel. and then you slide the smaller box into the bottom piece of the larger box and it creates a lip so slide the top box over.
i guess the third way (and i’ve done this before, too) is to create the two equal boxes, then create four flat panels that will fit inside the box to be the sides that stick up so the top will sleeve on. that leaves the bottom panel the same as the outside box.
hopefully that makes sense (since i did it fairly stream of consciousness).
the main point i’m making is it’s not difficult to do the basic two piece box. the harder part is editing to make matching edited edges (and moreso with the extra trim piece in there). but even then, it’s totally doable.
Lovely piece for sure. I think the waves would lend their curves well to rounded edges(sanded). Boxes with funky design elements are definitely on my agenda.
one of my mistakes was being slightly off on the length of those additional wave lines glued to the top half. and i ended up sanding after gluing with little sanding sticks. total PITA.
i really did think about rounding edges, but are a couple of places my fingers may have cracked a little and feel tenuous to me, so i’m afraid to round those.
next box. i bought a set of these last month to test out for rounding box edges.
