I will read those links, thanks. I guess Im just confused, as someone who opens someone else’s design, it may not be immediately obvious if it shrank it or not, and so to do a X1.333333 to the size could oversize it if it was an inkscape svg to start with. Hopefully the links will help me figure out how to know, without wasting a sheet of draftboard to check each time, lol
You got it. Best thing to do is ask the designer if you can. But yeah, knowing the potential is out there is half the battle. Most people use Inkscape and Illustrator. A few are picking up AD now.
For the record, I’m still getting “This SVG is Invalid” in Illustrator CC 2019. (Cc: @dan )
And @Houdini7’s Affinity export has the walls at 8 inches tall when I open it in AI.
Does anyone have an assembled picture of this tower? I just cut one out and other than the obvious side pieces (sorceress lady, wolf barbarian guy and amazon?) I’m not sure where these are supposed to fit. Certainly a bit of trial and error but I was never good at this part so any guidance would be awesome
I’ll reverse engineer it and do some “playing” myself then Thanks for the idea … I will be avoiding glue as much as possible in the future for sure. Not only do you not have to wait for the glue to dry, tapping with the hammer and watching it come together so fast is so satisfying.
I agree that the serrated tabs hold together great, but it was not easy assembling this thing! A tip for others who don’t want to waste as much draftboard as I did - I broke two pieces trying to tap them into the sides. They were, unsurprisingly, the U-shaped support for the basement door and the funnel with the deep divots in it, both of which are difficult to tap into place without stressing the piece too much. I went back to the piece of draftboard that I had cut them out of, and cut out the “mating” pieces for the divots and the notches in the support. I also cut a 2.5"x1.25" rectangle to support the inside of the U-shaped piece. I used masking tape to secure the mating pieces back in, and left them there while I tapped everything into place. Then I could remove them and it all stays together.
I’m hosting a virtual board game night tomorrow, and this should make it so I can keep all dice rolls in view of the camera. And I didn’t have to risk a run to the game store! (Which is closed anyway for the pandemic.) Thanks so much for this great design!
Thanks so much @Dan and @jeffbowman for sharing this great design! I made myself a Cthulhu-themed one today for use at tonight’s (virtual) game night, and it went beautifully…and I already have several other players wanting their own!
My virtual game night went really well! The only game with dice that we ended up playing was Can’t Stop, but that one gave my tower a workout with me rolling dice for everyone.
The only problem with the gathering was that since I was running games all afternoon and evening, it’s after 10:00 and I haven’t eaten anything except two chocolate chip cookies that my son baked. Time to go have a late dinner.
Tiffanyanna’s Husband (Paul). The serrated tabs are awesome. I think they should become a new standard. I think I may know what may be causing the scaling problem.
Apparently, when Illustrator saves SVGs, it saves the width and height info in a proprietary way that other apps can’t read. Since it’s an SVG (scalable vector), there’s no way for applications like Inkscape to know how big it should be, so it uses the DPI (usually set at 90) to try and figure that out. Btw, other apps save the width and height as part of the metadata. This means if you create something in Inkscape, it should open fine in Illustrator, it just doesn’t work the other way around.
The good news here is, if you ever open an SVG that’s from illustrator in another app, you can usually increase the size to 133.33% and it’ll be perfect. Also, it’s important when buying an SVG from another person to make sure they give you the dimensions so that you’re not left guessing. In this case, @dan told us it was 6" x 3".
