I picked up our Pro unit from the UPS depot this morning. I Finally got to the point to try to print the Founder Ruler and I do not see it on the App Page. I did print the mini puzzle. It cut out, except that the kurf seems a little wide. I do not know if this is intentional.
Does anyone know where I should be able to find the founders ruler?
Don’t believe the gap in the puzzle is intentional, just not possible to get it smaller the way it was cut. Commercial puzzles are created differently. The gap between pieces on the catalog puzzle is just the kerf of the laser for a particular material. Only way to get it tighter would be to cut each piece independently (sides of the pieces not sharing a side or touching) adjusting the pieces for kerf.
I just checked my app page and it’s there. At the home tab you should see several designs on the left two thirds of the page. If not, keep scrolling down and click the show more button if needed…it should be there titled Glowforge Founder Ruler.
The kerf measurement is material, power and speed dependent, so you basically have to make a test cut and measure it. I often start with about 0.2mm as a guess and work from there when I’m doing test fit.
