I had never gotten around to redoing this for when the bigger area got pushed. One of the challenges is that if you only cut and score, you could do a inch wider.
Edit and Addition: I thought some folks would like to have the outer numbers converge on the corner and 0,0 is in top left corner if you use acrylic and print in reverse so that you flip it over and numbers and ticks are on the bottom. That way you avoid parallax in measurement.
Edited: fixed the number 10 on the thinner shorter axis. Had it backwards or reveresed or whatever you say to have it come out right.
Here is how it relates to engravings in the GFUI
And here it is with the engraving converted to scores. I’ll think about this design a bit and see if I can come up with something that I can do the bigger object. I could use a single path font for the numbering and just score the tick marks.
