I find that saving something as a DXF often loses the exact dimensions of the object I created in Fusion.
To mitigate that, in the sketch I want to export, I create a rectangle around the whole sketch with a known dimension. So if the object I want to cut is about 2"x8.5" I would probably put a rectangle in the sketch around it that is 4" x 10".
When I import the DXF into Inkscape, I “Select All”, specify the size of that object is 4" x 10" (in the toolbar at the top). I now know that the Inkscape version has the same exact dimensions as my object in Fusion 360. I can then remove the rectangle.
Do you have another way of making sure the dimensions are the same?
I found that, as described by @polarbrainfreeze, that I had to resize the imported DXF in Inkscape. Be careful when scaling the object in Inkscape, otherwise your lines (strokes) will scale with the object making the lines thicker.
This image was scaled AND the lines/strokes were scaled with it, producing thick lines.
And this image was scaled maintaining the line/stroke thickness:
There is a button that you want to ensure is “up”, which will leave the lines/strokes their default thickness which scaling/resizing the object in Inkscape…
I did another test and created a 60mm square in Fusion360, exported to DXF and imported into Inkscape. ***Note that the imported object was slightly larger when imported (60.282 x 60.288…notice different size/dimension) but this can be corrected by selecting all and setting the size…
I did not know this. Usually I would make all line thicknesses to 0, scale my image to what I want and then make the line thicknesses the width I wanted. That way, I knew the image was the size I wanted.
