a case for the gantry speed being the same pro vs. basic is all things being equal when the laser is not being powered you want to move as fast as you can to where you need to energize the laser again because it’s dead time not doing useful work. So why not use the same movement parts for your maximum speed time. It would provide one set of parts to stock and maintain and one set of variables to account for.
A software enabled selling point for the pro as part of 100% premium?
everything we’ve heard active peltier? cooling 5W more power should enable a slightly higher engrave/cut speed at the top end, and a longer duty cycle. No need for a software tweak to enable it.
The shorter cut times are a combination of higher output power, better optics, and better cooling. Linear top speed should be the same.
