Hi,
What is the size/dimensions of the bolt/screw that is used to lock the gantry arm in place. There are bolt-holes on the right and left side of the gantry which appear to line-up with holes in the middle of the glowforge, just between the belts on the left and right side of the enclosure.
I assume I should be able to line-up the holes and screw in a bolt. I just don’t know what size bolt it is.
