How do I get around the auto focus override glitch?
Specifically where the machine ignores the material thickness & manual focus if it’s too close to the auto focus reading?
My laser consistently cuts very poorly on all dark materials and I’d prefer not to mask the entire surface with masking tape every time. Keep in mind the same settings for the same material (but brighter color) will cut consistently every time.
The laser (IMO) should not even run the auto focus before cutting if I’ve manually set it for each cut.
I now have to build into each cut a series of bogus cuts just to see if the dang thing is going rogue.
