My Plus is not cutting through medium draft board, I cleaned it and made sure that the power is at full. It goes through the entire process and moves back and forth but prints nothing. It also sounds like its banging around in there when its moving back and forth. Please help
Check your settings. They default to max speed and 1 power so if your design has a lot of sharp corners making that turn at max speed will "bang"a lot
