I see this is a common issue and have tried all the suggestions in other posts but my GF remains offline when its not. It does say calibrating for a few seconds then goes back to offline. What is my next steps?
The support troubleshooter for this is here:
https://glowforge.com/support/topic/troubleshooting/wi-fi#glowforge-is-offline
From your description is sounds like it is getting intermittent Wi-Fi connectivity or perhaps low bandwidth.
I’m so sorry you’re having trouble. As @markwal mentioned, it sounds like you might be having Wi-Fi issues.
- Turn off the computer, phone, or tablet that you’re using
- Turn off your Glowforge
- Unplug your modem
- Unplug your Wi-Fi access point
- Wait one minute, then plug everything back in and turn them back on
1. Improve the signal path between your Glowforge and your Wi-Fi access point
Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
- Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
- Relocate your Wi-Fi access point closer to your Glowforge
- Move your Glowforge closer to your Wi-Fi access point
- Install a Wi-Fi range extender closer to your Glowforge
- Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
2. Reduce electronic and Wi-Fi interference
If the trouble continues, could you please try the following and let me know how it goes?
If you have a smartphone that can create a Wi-Fi Hotspot, let’s see if that works better.
- Instruct your phone to create a Wi-Fi hotspot (search the internet for instructions specific to your phone)
- Place your phone on top of the right glass panel of the unit
- Hold down the Glowforge unit’s button for 10 seconds until it glows teal
- Go to app.glowforge.com/setup on your laptop or desktop
- Follow the instructions on screen
- Try a few prints, and take note of whether your Glowforge remains online more reliably
