Hi everyone, I would like to use kraft-tex with glossy (metallic) finish but I cannot get any information on the material that the metallic foil is made of. Has anyone tried to laser it or knows the composition of the foil please?
This is the material I’m talking about: https://www.linencookie.com/en/kraft-paper-fabric/990-glossy-kraft-paper-fabric-goldcaramel-100x150cm.html
Thanks!
evansd2
October 28, 2018, 11:03am
This looks a lot like what I just posted about:
So I made that mask (see MOAG) and part of it used gold cardstock.
You can see the product page here, though i am not sure it’s available anymore:
What’s interesting about it is that it just can’t cut all the way through. The metallic layer appears to be actual metal foil. This led to an interesting method:
Cut from the back, (350/50/1x) and you get perfect score lines. You can then punch it out, it peels out almost like you’re opening a really easy pull-top can. The end result is a per…
system
Closed
November 29, 2018, 1:03pm
