Glowforge Interface - Using the Trace Tool šŸ¤”
If the outline is set to cut and not engrave, it should show only the outline.
@Jules
Every single time I see one of your tutorial posts —- I instantly turn into Tina Turner and start singing
You’re simply the best, better than all the rest
Awwwright! :smile: :+1:
(The best at what has yet to be determined though!) :wink:
Thank you @Jules. i ā€˜read’ the manual and maybe because i’ve used it a bit now, this makes so much sense and you’ve provided info i don’t remember learning!
Along those lines, when you import i.e. a graphic… a pattern that is in a square shape and you want to print it but want it printed in a circle so you use the shapes circle for the cut. Is there a way to delete the ā€˜extra’ part of the graphic you don’t need to cut or does that all need to be done in a design software?
Thanks!
I just leave it on there…it does bleed outside of the lines a bit, but it’s easier than trying to trim it in a weird shape.
(You would need to create a mask and then rasterize it with the original graphic if you want to actually change the shape, so that has to happen in outside software.)
That’s what i figured but since you can delete with the scan tool, thought i’d ask:-)
I scanned a handprint and saved as an svg file. How can I clean up the file? Nothing will let me in software like Inkscape, etc.
Your best bet is to save that as a .png file and open it in a raster editor (GIMP, Photoshop, GetPaint.net). Inkscape will open the .svg container just fine, but it’s designed to work on vectors, and only has limited editing ability for rasters (which the scan will be).
If you don’t have the ability to change it, you can open it Inkscape, and then in the File menu click Export PNG - you’ll then have a .png in the same folder you have the .svg saved in (with a name something like ā€œExported Imageā€)
I don’t have a trace feature. Should I upgrade to premium to have it?
No, it is not a Premium feature. In the app.Glowforge.com app, when you click Create do you not get the option "ā€œCapture from cameraā€? That is the trace function.
Oh I see it now! Thank you!
I’m using an IPad and my problem is I can’t get a virtual keyboard on the screen to do the commands. Any suggestions? Am I missing something?
On my phone, I select a design element with a press and hold, then choose the operation from the flyout menu (group, ungroup,copy etc.). I am not certain the interface allows for a virtual keyboard.
