all of a sudden my glowforge is making a double pass in the cut setting,same vector, same material
This is most certainly your file. Open the file in your graphics program and magnify the line in outline view mode. You will see two lines. You can also share the file here if you want someone to take a look.
Your correct this a new vector, my design ,the the score line and cut line touching, thank you
