My glowforge was working fine till yesterday. It is not cutting properly since this morning. have a look in the pictures bellow.
What to do?
Generally the first thing to check is to clean all the windows and lens. Instructions for that are here:
Yes i tried that but no luck. its doing the same.
What does “not cutting properly” mean? Are those cuts not all the way thru?
It’s cutting in 1 to 3 mm at some intervals, instead of cutting continuously. I tied cleaning all lenses as per cleaning instructions, but didn’t work.
Couple of other people have recently mentioned a similar issue…could I ask a couple of questions? (We are trying to figure out what the issue might be.)
Sorry, I know that’s a lot of questions.
I have this machine for 3-4 months.
It is basic machine with external filter
I may have used it for 15-20 times
It is connected to constant power supply, and only glowforge is connected to this circuit. Have not connected any new device to this circuit.
I can see a purple flashing on left as well as in the glass tube, but it is not constant while cutting, it used to do.
I have restarted the machine several time, while I was trying to troubleshoot.
Thank you
Parag
Thank you, that does help to narrow it down a bit.
I’m wondering now if it is a power supply issue (machine) or if the tube might be going out. (Bad tube.)
And I’m sorry there’s no way for me to tell…support might be able to give you some more information by pulling the logs for the machine, which I’m sure they’ll do once they see your post. (Hope it winds up being a simple fix…good luck!)
It may be antidotal but I had this problem recently as well when I was batching score lines on similar wood shapes. It seemed to happen when I used the “Set Focus” and then moved the art a little. If I lined up the art, hit set focus, and just printed, it did not do this.
That does sound unusual… very curious.
I’m sorry your prints aren’t turning out as expected. To help narrow down the source of the trouble, could you please run this test print on the default settings?
The print failed for Gift of Good measure
Thank you
Parag
I see you emailed us about this and we’re working on it there, so I’m going to close this topic.
