I got a new black lid cable this week and my glowforge will now cut, however it is NOT cutting correctly. What you see on the screen is NOT how it’s cutting on the wood and the lines are crooked. For example that middle to the A’s are cut outside the A not even close to where it’s supposed to cut. I have set focus. I have tried 3 times to recalibrate and it says no changes were made. I have been down 9 days now and can’t afford this.
Welcome to the forum.
Can you share a photo of what you are discussing?
I am happy to hear the new black lid cable is now allowing you to print once more! However, I am sorry to hear that you are now having trouble with alignment.
We’d like to have you try a few troubleshooting steps for us:
- Turn off your Glowforge.
- Check for small pieces of debris or dust.
- Check the lower door to make sure it closes all the way. It may require some force to open, but open it, wipe any dust off the edges, and close it all the way.
Remove the tray and clean any dust or debris from the surface underneath. Pay careful attention to remove all debris from the four dimples where the tray rests.
Check the lid to make sure it closes all the way. Small particles of material, such as dust or debris, can prevent it from closing completely.
- Check the surface your Glowforge is on to make sure it’s flat. Ensure it is not twisted slightly and that there is no debris propping up one side of the machine.
- Turn your Glowforge back on.
- Place Proofgrade material in the part of the of the bed that you are having the most trouble and print the Gift of Good Measure using the default settings.
- When the print finishes, leave the lid closed and wait until the fans stop and the picture updates. Without moving your artwork or your material, take a screenshot of the Workspace to show us the difference between the artwork placement and the actual print placement. Make sure to include the rulers in your screenshot and show as much of the bed as possible.
- Mac: Press Shift-Command-4 and click and drag a box around your image. You’ll find the screenshot file saved on your desktop.
Windows: Click on the Start Menu and type “snipping tool”. Open the Snipping Tool > New then click and drag a box around your image. Click the Save icon and name and save your file.
- Send us the screenshot along with the date and time of the print, and we’ll investigate.
It cuts sometimes and sometimes it doesn’t I either want a new machine sent to me or a refund, asap.
I completely understand your frustration in prints not turning out as expected. In order for me to determine the next best steps, I’ll need to gather a little more information. The best way to do this is by performing the test print that I mentioned above. Here is the information again -
Let me know if you have any additional questions when responding with the results from the test print!
I can see that you’ve also reached out via email and that our support team has contacted you there. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic.
