When I turn on my Glowforge, the lights come on, I hear the sound of the water pump, then the water pump stops and I just hear fans - the normal startup sounds… and then the print head doesn’t move and it stays in “Offline”. I’ve tried power cycling it a few times.
I tried pressing the button until it turned teal, and going through the setup - my laptop found the Glowforge Wifi, and said everything was fine, but still nothing is moving, and the unit shows up as offline in the UI.
Thanks! I had a quick look in the forum, but I didn’t see any posts with similar details in the headers. Should have looked a bit harder I guess.
I had my GF sitting in the background on while I was typing this, and literally exactly at the same time as I hit “Post”, the GF started moving, and now it shows as calibrating. fingers crossed Problems in the cloud are annoying, but much less annoying than a dead GF.
This is why a way to run off the cloud (in an offline mode) would be sooooo nice, so the entire community isn’t shut down when there is a power outage/glitch at the home base!
(and I had some offline errors today too–wasn’t sure if me, as my modem/network has disconnected itself a couple times today since I switched to the newest version modem from Comcast yesterday–and down 6+ hours then, too. Grrrr, but able to get it set up back & running last night.)
