The glowforge is showing offline when I connect through the app. I have shut both it and the computer down so that they would reset. The glowforge does not do its calibration dance when it starts up at all. Worked fine yesterday during the day and at the end of the day it went offline. Still shows that today also. Tried to reset up the glowforge on a secure network at our school and it shows up with an error message. Any ideas would be great. We have a deadline to make plaques for our school and this puts a crunch on it. I have also sent in a support ticket. Just seeing what else is out there.
It’s difficult to understand exactly what has occurred by your description. Step by step. You said it was working yesterday. On the same network? Did the school IT folks do anything special to give you access? If same network and and a standard setup, you can probably just go through the setup procedure again by connecting to app.glowforge.com/setup with your computer and then holding down the print button down for 10 seconds until the button glows teal. Follow the directions.
If you have never been on this particular network it may use a protocol and security settings beyond what the GF can support.
We had the tech guys look at the wifi connection and it has a real strong signal and that it is connecting to the internet. It looks like it is connecting when the teal light is on. It still shows that it is offline. Any ideas??
When the teal light is on it should only be available for you to connect from your computing device to the GF. Then you tell it to connect to a specific network at which time it will disconnect from your computing device and connect to your network and internet.
There is a video somewhere in the tutorials showing the process. I don’t have good access to search right now.
I have tried multiple times when the teal light is on to connect, but in order for the teal light to come on I have to hold the button down. I have a device error that pops up when I try to connect the glowforge to the school internet now. Is there a factory reset on the glowforge to bring it back to the factory settings.
