Glowforge Pro issues with starting to cut
Everything was good till I hit print, gantry moves to the middle and stops, no print. Several times before it ever printed, a “Cooling” message came up and of course it never came back to work. I tried turning GF off for several minutes, that didn’t help. Turned off and even unplugged over night but still didn’t work this morning. Anyone else having issues???
How’s the temperature in the room with the Glowforge? If it’s above 75F it may be too warm to print.
Not above 68 degrees!!
Teri Wells
916-591-8225
68 degrees
Teri Wells
916-591-8225
Teri Wells
916-591-8225
You might want to remove your phone number. These forums are public and therefore susceptible to data skimmers. Easy recipe to end up on all kinds of unwanted call lists.
