Whether I’m at a big-box store, a craft store, or even the local ReSource shop, I often ask myself “Will that fit in my Glowforge?” Usually, I’ve forgotten my tape measure and as cute as they are, I don’t typically carry a Founder’s Ruler with me.
I wanted something I could keep on a keychain or attach to my backpack, so came up with this.
The long axis represents the current maximum depth an object can have if you remove the crumb tray (1.5 inches thick + 0.5 inch for the current max above the crumb tray bed). The short axis to the right is 0.5 inch, a quick check if an object will fit on the bed.
I expect to refine this over time, but wanted to go ahead and share the SVG file, too.
I love this idea. Would be good to have as a handy reference when calculating thickness of materials when the crumb tray is out. Write in the dimensions so the math is easier.
Nice. I’m a tad lazier. I just keep my left hand with me. The distance between the tip of my middle finger to the 2nd joint is exactly 2".
I’ve got other body part/measurements that I’ve determined and memorized so I can measure from 1/2" to 3ft. It’s very handy because like you, I don’t usually carry a tape or ruler.
If you’re not anal retentive about your phone, you can mark the back edge (or tape a fabric or paper measuring tape to it) and you’ve always got a ruler in your pocket.
