pugh
April 12, 2016, 2:57pm
Is there any more data about the ventilation requirements for the Glowforge, such as CFM or static pressure? I understand that the Glowforge has an internal fan, but we may need to run a significant length of duct work to vent the glowforge.
joe
April 12, 2016, 3:08pm
It was discussed on here previously, and I thought someone stated what the CFM is, but I can’t find it. I did find this from @dan .
@karaelena I don’t remember the CFM rating off the top of my head, but as @rpegg says, they’re variable speed. I’d plan for a booster if you’re running over 8’.
There are several topics about ventilation. Some topics discuss the filter that one upgrade to. Others talk about possible external venting solutions, homemade or purchased. @dan_berry has one concrete recommendation about CFM.
The power consumption used by any system is not a reliable measurement of how much air the unit moves.
You really want to use a CFM measurement, regardless.
I think that something around the 120 CFM range would be plenty, especially if it’s well sealed and has good suction. And don’t forget, the GF comes with an internal fan that’s standard as part of the hose attachment. So you won’t be doing all the work with just one filter/fan.
That DIY laser filter is well done, but seems to have faults.…
Here is another:
and here is another:
I purchased the Basic unit and want to build an insert for my window that I can use to connect the vent hose into. I live in NJ and it is going to be getting quite cold so I do not want to leave the window open completely. What size hose comes with the unit and are there any other precautions I need to think about? I saw in another thread that someone mentioned a need to isolate the unit from the cold air coming down the length a tube. Do I need to figure something out to block or warm that ai…
and here is one that discusses CFM.
So I’ve been thinking about cancelling the filter on my Glowforge and hooking it up to a Dust Collector I was going to put in a shed. I little more expensive but it will solve the workshop dust issue from the other tools (currently just using a shop vac). I also have no window, only an exterior door so I will only need to create one 4" hole, and a small hole for the electricity, and it will solve the dust issue and exhaust the laser fumes when I hook it up. I’m assuming if I put a speed cont…
