So I have My Glowforge yay! I unboxed it, was going through the process of setting up and hit a snag - the GF doesn’t send out a Wifi Signal and the button isn’t glowing except for when it moves - it’s acting like it’s self adjusting.
Have no idea what you’ve done so far… If you hold the button down for 10+ seconds it should turn teal and you can start the wifi connection process per the manual.
If I remember correctly at that point you connect to the GF broadcast directly from your computer and tell it the name of your network. Then it connects directly to that. But it’s all in the manual so don’t want to give partial info.
yeah I’ve got it and started down that path, but then it started calibrating the head (yes I agree that is what it sounds like it is doing) and lost the signal. Hopefully the 10+ seconds works. I held it down for about half that and tried turning it off and unplugging for the night as well to no avail. we’ll try the button holding again
I’ve done it just to see what happens, but a long time ago. It’s the standard method of changing wifi networks. Have never lost the connection in 7 months.
BTW: Here is the GF wifi troubleshooting online section. I have no idea whether folks who have not received the unit can view this. But you should now have access.
Occasionally, Wi-Fi setup succeeds and still shows an error message. Since your Glowforge started moving, it’s likely your connection succeeded. Would you try the following please?
