I’ve seen only one topic so far on the gold pins on the laser head, but didn’t really see an answer. I cleaned the air assist fan yesterday along with other areas, ran several cuts today with no issues, then suddenly yellow light. Went to check the white cable upon someone’s suggestion, and checked the head and noticed one of the gold pins is not popping back up.
Mostly the answers are buried in the comments, I found this searching for “pin depress”
TL:DR - Wipe the pins with a Zeiss wipe, and scrub lightly with a pencil eraser.
I hope it helps!
Thank you so much…I’ll try this…!
