I just received my golden email…3 days earlier than I expected!
The model must have adjusted late today, because when I looked this morning, it was still showing March 9. Well, I just told them to send it on, so I’ll have it hopefully really soon!
Not yet. I’ll go in the next few days to pick up a dryer vent. I guess I’ll just put it through a piece of plywood. Not sure. I’m just going to use the cheap plastic vent that I’ve seen @Jules and some others use. Seems to work fine.
You should put up a picture and show the Hive here what you’ve got to work with… You may be surprised at the ideas, you never know. Often, a different perspective can yield unexpected results.
Hard to really tell in a picture with no reference. I really hope that seat works for you, but you may want to think of a Plan B.
Tell you why. They are way bigger and heavier than you anticipate.
I suspect the exhaust port on the left side will not be lined up with the window and it does not appear that you have enough clearance to shift it forward.
I hope I am wrong because I agree. It does look like the perfect spot.
Hmmm…good point. There is not much room in the depth category. I might still use this location and just build a little platform to sit in front of the window seat that is at the same height. Then, I could shift the GF forward to make room for the exhaust port if need be.
