Golden ratio calipers the plans
#1
If you need to check if something is at or about the golden ratio. If you don’t know what that is you don’t need these. :wink:
Cut the inner holes first then the outer outlines.
As you can see, I’ve done these in two different :proofgrade: materials so they should work in any of the 1/8" :proofgrade:
The basic shapes came from plans offered by King’s fine woodworking but I had to completely rework them for laser cutting.
I have included the Fusion file as well as an SVG so if you need to tweak the hole size or something.
I used 1/4" Chicago screws from Amazon.
golden ratio calipers.zip (597.8 KB)
#2
It’s lovely even if I don’t need it! Thanks!
#3
Make them and you will find a use for them. The golden ratio is everywhere and is naturally appealing.
#4
My goodness but those are lovely
#5
Cool! Looks like the center-finder from way back when here on the forum.
Thanks Mark!
#6
Thanks for sharing
#7
Wow those are really great :heart_eyes:
