Wow! Very nice.
Those need to be made into a coffee table or something!
I havent gotten around to the variable power when it comes to engraves yet. these were all done with dots
Just a heads up.
When I was playing around with 3D engrave I found out the maintenance schedule advances rapidly.
I was forced to clear the exit grate and interior about every 8 or 10 engraves. Lot of debris from this type of engrave.
Looks like you are probably due for a good cleaning, even with the small 2x2 size.
This is amazing! 3D engraves are one of my favorite underutilized features.
I have discovered that increasing the volume of air moving through has the smoke hanging around a lot less and thus causes less build up than without the help. Different species have different amounts of course, with oak being bad and walnut or maple a lot less.
Those are very cool. Inspiring!
You call these tests - I call these great examples of 3D engraving!
This might tickle your fancy then lol. engraved both sides and made a quick cut file in inkscape to knock the flashing off between the 2 halves.
tutorial me pleeeeease. I’ve never had success with this.
Is there a tutorial on using grey scale and/or variable power?
The 3D setting is kind of plug and play once you have the art right (like everything else
Here’s a great write-up on how to conceptualize the art: Tutorial: 3D Engraving Depth Map Concept, using 2D Design Software
and this post: Anyone know anything about 3d engraving files? links to a Photoshop how-to, and 2 posts down from that links to another site with a guide…
Good luck!
Just to give you a visual, here’s a rabbit hole of greyscale images that work with 3D engraving.
Awesome link, thank you.
Thank you so much for sharing. Really nice work.
I love you and hate you a little bit right now - there’s dozens of those I want to try!
Aww, love and hate you too man. I have dozens of “I’m bored and want to engrave something cool” tiles laying around, now you will too. You’re welcome.
Neat! Yes, I’ve used electron microscope images before (my draftboard ukulele’s label: it was a flea) and they really lend themselves to laser engraving.
Beautiful work!! Did you use any masking paper?
