'Tis the season of the witch.
I’m getting in mood to decorate.
It might be a bit loose without paint.
This is so cool, thank you.
Thanks very much. I see a candy dish favor.
Well, you are in luck.
This so happens to be made with a my first modifier for cuttle. So you can change the dimensions.
If anyone does, please share what yours looks like here.
Adorable! Thanks!
Lucky for me, I already have a Cuttle account. Thanks again.
So cute! I love the details on the top of the coffin.
Thanks! I can make my neighbor happy with this!
Spooky! Great stuff! What fun!
If you need any help with making modifications let me know. I still am very new at working with Cuttle. I added parametric variables for the thickness of the material and the depth of the box. The outline shape is left to the user.
Thanks, I appreciate the offer!
Thanks for the share the more we share the better we become
This looks so fun! What material is this set up to use? I have made a few premade things that then won’t go together. I assume my material is different therefore the slots won’t fit.
This is awesome, and I saw it in the Cuttle discord. Thank you for sharing it, it would definitely make a fun project, and I’ll add it to my Cuttle dashboard. Who knows, maybe I’ll cut a cardboard cat bed with the parametric ability!
This is great! Halloween is my fav holiday
Welcome to the forum.
Having things not fit together is a frustrating experience that almost all new users have to get through. You are right to double check what material is being used to help reduce the number of project failures - although every failure is a learning experience. This appears to be medium draftboard sized material which makes it approximately 1/8" thick.
A cat bed shaped like a coffin? Gotta see it! Are you going to devise bat wings for your cat as well? Now wouldn’t that be fun…maybe. How tolerant is your cat?
I did not download the file because to me ——caskets are creepy but it turned out great!!
Thanks for sharing @bwente!
FYI it’s currently free to create a Cuttle account. Also you don’t even need an account to view, export (SVG), or edit the Coffin Box project that @bwente shared. You only need an account if you want to copy the project to your own space / save your changes.
Oops. I had it my original post and must have deleted the line when I was adding the photos. @dklgood is correct!
Yes, the file posted is for PG draftboard it might be loose since I rounded up for paint. If you use the link to the Cuttle version you can change it to something thicker or skinnier. I did two test fit ones using different settings.
