Saw something similar online and decided to try and reproduce it as a Glowforge file. Cut all pieces, assemble the frame and lock it together with the round disk. Hang the snowflake inside the frame.
All parts lock together if using draftboard. I haven’t tried it with anything else. The blue star is optional in case you want to cut an acrylic center for the snowflake.
Added an assembled photo. I haven’t applied any finish to the draftboard, but I did cut the center of the snowflake using white acrylic. Also just bent a paper clip to hang the snowflake, I’ll bling that a little more once I stain and seal everything.
Thanks so much! That really helps it - I didn’t visualize it quite as well as in the photo. This design has lots of possibilities. I’m thinking using clear acrylic for the snow flake, with a blue acrylic star, and cherry or walnut stand.
I really like this design but can’t seem to make it work. I’ve right clicked and saved as both a png and a bitmap file which are the only two options I get and get the same message on my glowforge.
Error
An error occurred on your Glowforge. Please refresh your browser before printing. It may also help to turn your Glowforge off and then on again.
You’re probably using Microsoft Edge, which for some inexplicable reason does not allow you to download SVG files. You need to use a different browser.
