I whipped up this Archimedean Spiral but when uploading (three times so far) it gives me the whoops error message. I resaved the file to a tiny one (so i could resize in the UI) even on the last attempt but still not working. Any ideas why? Here is the file
Did you log out and back in? Are you logged in on multiple devices? Have you had it open and running for a long time (days)? Powered the GF down & back up?
All of those have caused me issues before.
I’ll be glad to check it if no one beats me to it…currently orbiting.
I will try all of those. I just logged in, did one print and then designed the next print (15 min) then tried to print it.
I relogged and it worked seamlessly, hahahahaha
Yes, if I start my GF after the computer has been hibernating for the night I need to log out and back on. Otherwise will get the error.
Always a good practice to log off and back on. Just take 30 seconds or less.
Thanks for remarking on that – we’ll check it out. And I’m glad it worked when you re-logged in!
