(Work in Progress) Height Adjustment Tool. When working without the Original Crumb Tray and Uncertified Material**. Should give you an quicker way to adjust and type in the material thickness, when using without the original crumb tray. Just measure the new crumb tray and the material thickness(in inches/decimals) and put into the corresponding areas. Should give a generally accurate measurement to put in for the adjusted material thickness. The highlighted colors meanings: Red(Too Large for the machine) Yellow (add more height to the bottom tray)
Please remember this is a work in progress
Height Adjustment WIP.zip (9.4 KB)
