Is it something you traced using the GUI (Glowforge user interface) or is it your own file that you uploaded? You can engrave using either vector or rastor (also called bitmaps) images, but to cut something it has to be a vector file. If these terms sound like Greek to you, you should head over the the tutorial section and go through some of the learning files. These are a good place to start!
