Looking for suggestions: I moved the glowforge for where I initially had it set up and now it’s offline. I have tried everything and nothing works. I desperate to get this back online. I am not tech savvy. I would appreciate any help! I did a hard rest and there is no connection. I have tried different devices and still cannot connect.
Are you still getting a strong WiFi signal where you moved it?
Try using your phone as a hotspot and connect the Glowforge to that. If that works, then you need to improve your wifi signal at the location you moved the machine to - or move it back.
Hello @orozcoe23,
I took a look at the logs for your unit and it looks like your Glowforge was able to connect successfully to your network, but it may be having trouble maintaining a stable connection. When this is the case, you won’t need to go through Wi-Fi setup again, but you may see an “Offline” message.
- Turn off the computer, phone, or tablet that you’re using
- Turn off your Glowforge
- Unplug your modem
- Unplug your Wi-Fi access point
- Wait one minute, then plug everything back in and turn them back on
Improve the signal path between your Glowforge and your Wi-Fi access point
Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
- Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
- Relocate your Wi-Fi access point closer to your Glowforge
- Move your Glowforge closer to your Wi-Fi access point
- Install a Wi-Fi range extender closer to your Glowforge
- Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
Reduce electronic and Wi-Fi interference
I hope this helps. Please let us know how it goes.
thank you
| MorganW Staff
September 8 |
Hello @orozcoe23,
- Unplug your modem
- Improve the signal path between your Glowforge and your Wi-Fi access point
- Reduce electronic and Wi-Fi interference
thank you
Hi @orozcoe23 I just wanted to touch base - it appears your Glowforge has successfully connected recently, that’s great!
Could you please let me know if you’re still in need of any assistance?
