Help! Parts
ISO: Glowforge Plus Mainboard (NEWER REVISION — WCD SERIAL RANGE)
I need a replacement main logic board / motherboard for a Glowforge Plus.
My serial number begins with WCD-686, which means I specifically need the newer revision of the Plus mainboard (NOT the older revision used in PRH/KCU/etc units).
:check_mark: What my Glowforge is doing:
  • Inside lights turn on
  • Fans turn on
  • But NO button light
  • No relay click when powering on
  • No head movement
  • Only shows a teal button when I hold the button down
  • Won’t boot normally and stays offline
:check_mark: Troubleshooting completed:
  • Reseated lid ribbon cable
  • Reseated hinge cable
  • Hard power reset
  • Reseated all visible connectors on the mainboard
  • Verified the power supply is delivering partial voltage
Everything points to a failed main logic board (Plus model, newer revision).
Located in Southern California
These are also the exact symptoms of not being able to get a wifi connection.
I assume you’ve troubleshot your wifi situation? A phone hotspot connection test is needed if not. There are help pages about this, I’ll pull them for you.
