guys..this should be simple but I cant seem to navigate where to connect to same wifi and change to new password to connect. i hit til teal glow but no connect to wifi visible and if i download comlplete set up exe i just get glowforge symbol. glowforge pro ive had for 5 years
Just to clarify, you have not changed your internet provider or setup?
Yes we changed internet provider. Now glowforge don’t work. Need to know how to reset it back up to new provider
It was hooked up to starlink but then we had to change password so yes internet provider has not changed just password
Hold down the print button until it flashes teal, then go through the setup process as when you first got your machine. Glowforge - the 3D laser printer
You should see your internet listed in the network list. After you click on it to join, you will be asked for the password.
If you internet is not listed in the network list, you may not have a 2.4 gHz band broadcasting. You must have 2.4 gHz (not 5G) for the Glowforge.
5 GHz, not to be confused with 5G cellular service.
We changed to Verizon and the routers use a feature called Self-Organizing Network (SON) that combines both 2.4 GHz and 5 GHz into one name. I cant get my Glowforge to connect.
There are a few things you can do to overcome this issue. First, you can contact Verizon and ask how you can turn off the 5G briefly so that you can connect to the 2.4gHz band if you cannot directly address your router. Second, you can use your phone as a hot spot and connect that way. Finally, you can try connecting your old router to the new modem. This solution is “clunky” but can work. I have an ancient (Apple stopped production in 2018) Apple Airport base that holds my music and was my wireless router for a number of years. I use it for my very old Philips Hue bridge as well as my Glowforges.
Chat Jeepie says:
On most Verizon routers, you can disable the Self-Organizing Network (SON) feature so that the 2.4 GHz and 5 GHz bands have separate SSIDs.
The steps are generally:
- Open a browser and go to 192.168.1.1.
- Log in to the router (the admin password is usually on the router’s label unless you’ve changed it).
- Go to Wi-Fi or Wireless Settings.
- Find Self-Organizing Network (SON).
- Turn SON Off.
- You’ll then be able to assign different names (SSIDs) to the 2.4 GHz and 5 GHz networks, such as:
- MyWiFi
- MyWiFi-5G
If you don’t see the option, tell me the model of your Verizon router (it’s printed on the label), such as:
- Verizon CR1000A
- Verizon CR1000B
- Verizon G3100
- Verizon G1100
Some newer firmware versions hide or move the setting, but on Verizon’s current FiOS routers it’s usually still available. Let me know the model and I’ll give you the exact menu path.
Of course as with anything chatgpt sone of the details may be wrong but in principle this info seems pretty correct
