Help turn off my fan
ugh, I have been using a inline fan for the past year after I cleaned my glowforge today the internal fan started up and I can’t get it to stop. I forgot how very loud it is. Thanks for any help
If the setting in the UI is not turning it on and off, then you have either damaged it or the connector/wiring between the fan and the distribution board on the left side. There’s no fix for that.
You could always just unplug it.
The fan will run at full speed if powered without a valid control signal, or with a constant 12V on the control line.
Click the three dots in the interface and toggle the filter on.
Hi, I did that alreay but thanks for the advice
