Help: upload file and delete intructions
Hello I need help I bought this file on Etsy and it has all the instructions on the file i tried to ignore parts of it but its too much and I cant seem to find all the parts on the left side to ignore all of the ones i dont want cut. Also I need to delete the name Alex. This was suppose to be a gift for teacher appreciation :cry:
Thank you
sticky-note-pen-set-cevron-digital.pdf (1.4 MB)
If this is a purchased file, you should not be posting it here for public view. That is almost certainly a violation of the terms of sale. Anybody would have the ability to download and use it without paying.
Which vector editing application are you using to try and modify the file?
I can’t really follow what you are trying to do by ignoring parts on the left side – simply move them outside of the print area. What do you mean by “it’s too much”? To delete an element in a file, simply select it and press delete. If this is using a name, I suspect this is a file is meant to be modified, so replace the name with the one of your choosing.
This looks like the instructions for the file itself. Did you get a SVG with the download?
I made one using an online subscription software called Cuttle, but since you already bought the one you want you should try using that one.
