Help with engraving pictures
#1
Hi do someone knows how to prepare a picture so i can engrave it whit my GF
#2
Yes, @takitus has a couple of nice tutorials for Photoshop if you are using that. If you are using GIMP or some other program, you might want to check the Matrix for tutorials on how to prepare a bitmap image (raster) for engraving. (Line 10)
If you want to just use the image as it is, you’ll usually get a pretty good result in the Glowforge if you remove any stray marks from the background and try to increase the contrast. Make it as clean as possible, you’ll get better results.
You’ll want to watch the image size. Really large images can take a while to process and might hang up in the interface.
#3
Thank you
#4
I 2nd the matrix…
#5
Thank you
