Hello people! I am new and just engorged with ideas. Ha. Appreciate your help to make them happen!
I am making layered designs; some that are intended to hang on a wall and some that are intended to hang in a window. For the former, only the top/front layer will be visible and for the latter, the two outside front/back layers.
So I only need a finish on the outside layers… seems wasteful to use the double sided finishes since one will be covered and glued. Questions:
Does it make sense to use the veneer on draftboard for the visible side?
Can I stick the veneer on the draftboard first, and then cut? (designs are intricate so trying to stick after cutting makes me queasy)
Or should I source a single sided material instead (if so, any suggestions)?
I think veneer on Draftboard should work just fine. But you will have to do some testing on a small bonded piece first; Draftboard settings won’t cut it.
No, you are still going to need to adjust power/speed to get through the two layers. Your best best is to use one of the many testing templates out there to zero in to the right settings. I like this one as it doesn’t use much material.
And now that we are talking about nonproofgrade settings, I need to move this to the Beyond the Manual category.
