When I try to cut out these pins the only thing my GF does is the engraving and cutting of the middle slit. It doesn’t cut the actual pin out. What am I doing wrong? TIA
honeycomb pins_v1.zip (4.4 KB)
There should be an outline that cuts as well as the middle slit. I never engrave because it takes too long. Can you share a screenshot of this file open on your interface? It should look like this
I agree with the engrave taking to long. I actually found another file in on another feed and it worked perfectly. Thanks for getting back to me so quickly!
