How close to the rear wall can you place the GF? Since there is an exhaust hose it clearly can’t be flush unless you have the filter, which I don’t.
If you turn the hose 90 degrees, how much space do you need behind? Inches may matter in the location I am considering.
(I am getting a Pro, but will roll the GF cart as needed for more passthrough clearance. I don’t expect to need passthrough the vast majority of the time, though.)
Won’t be be flush to the wall even with the filter since you’ll need a ducted connection between the two. I can measure how much room I’ve got behind mine tonight if you’d like, it’s as close to the wall as it’ll go. 6-8" worst case by my estimate
The other day I measured and was able to push the unit 4.5" away from a flat wall with the included foil hose, but that is really tight. 5.5" is a good minimum.
