I have been experimenting with leather some more lately, and I’ve noticed that it’s fairly easy to wind up spreading the soot from the cuts onto the material face if you’re not careful. Anyone have any tips or advice about how to handle the piece after cutting to avoid that? I considered light soap and water before unmasking but figured I’d ask for advice before I go down any paths since my leather supply is limited and I’d like to avoid waste as much as I can.
Odd, I haven’t run in to that problem … and I’m primarily cutting leather. Your first instinct is good: use a sponge with light soap and water along the edge, and that should deal with most of the charring. That same method should work to remove any charring on the surface, too.
Can you share a picture of what you’re talking about? Not a big deal, I’m just a tad curious since I haven’t really experienced this yet.
