How do I engrave on a concave cutting board?
Not going to be easy since the laser will focus on a flat plane. You may be able to split the difference between the highest and lowest point and use that as the focus height. It won’t be perfect in any case.
It’s also going to be dependent on how “concave” it is, specifically how tall the sides are in relation to the center? You only have about 1/2" to work with.
Thank you
