How to Update Wifi settings with your glowforge you currently were using
How do I update my wifi settings with my glowforge? I had different wifi settings before. Now my glowforge is saying offline. Please help?
Thank you
I think this should do the trick:
“When you first power up your Glowforge, the button will turn teal to indicate it’s broadcasting a Wi-Fi signal and ready for setup. If the button is not teal, no problem. Turn on your Glowforge and hold down the button for ten seconds until it turns teal. Your Glowforge is now broadcasting a temporary Wi-Fi signal.”
From: https://support.glowforge.com/hc/en-us/articles/360033633634-Wi-Fi
… and whatever you do, don’t hold the button when you turn on the power, press it a short while afterwards.
Holding the button at power-up initiates a wipe and you would lose all logs in case support needed to see them.
