Hey everybody, I recently re-installed Illustrator to the latest version and created a couple projects. Simple projects that would normally take a minute or two to cut.
I’ve been using my Glowforge for two years and Illustrator forever.
The first thing I noticed was the cut times were much higher than I expected. I watched the cutting and it cut everything twice, even though I know it was a single line cut. Also it wanted to assume it was an engrave instead of a cut.
My first thoughts were that Illustrator changed the way the app handles lines, or that the SVG export, which has changed a bit (more options) is somehow causing the line to thicken and become a shape.
Lastly after seeing some other posts, maybe it’s the update and not the files at all?
Any help or ideas would be appreciated.
