Image jumping
I am not. I take it you are.
Have you run the camera calibration?
Setting your material thickness exactly or, using the Set Focus feature can help. Incorrect thickness settings will make the camera image show the the cuts off from where they will actually happen.
If you need high precision, you may have to make a jig. There are lots of posts about doing that.
https://community.glowforge.com/search?q=Jig
Hope that helps!
