I’ve done everything I can to get this to work but it absolutely will not no matter what I do. I’m trying to make a Krispy Kreme style box for our pastor’s birthday. I love this simple design but need it to be dimensions of a KK box. I’ve attached the dimensions I’ve tried …
when it opens in Ai it is incomplete. What am I doing wrong or what do I need to change to get the box bottom and lid to slide over it in the proper dimensions??
Those do not look like your settings even if out of scale 365x285x55 is not the shape of a cube. I would double check your settings before you hit the generate button.
The picture above of the box is the example from the website of what the lid and base look like with their cube dimensions. The dimensions attached above are what I was using to get the lid and base to be rectangular but I’m obviously doing something wrong lol
If you put in the dimensions for the box you want then that should be the box you get but it will not hinge at the back like the KK box. Wood is stiffer than paper so will not “give” a bit to open that way and you have to work out the geometry so it slides up and down like your illustration box. I have used their boxes and not had an issue when used straight up, but none of the lines are connected so modification is more a problem than starting from scratch, which is what I do now.
Makes sense. I didn’t want it hinge I just wanted a simple base and slide on lid but can’t get the dimensions right. Any suggestions on starting from scratch and just doing it myself?
