Inkscape has released an early beta 1.0 version of its fine software here. It’s going to be mandatory for those of use using the latest Mac software, since prior Inkscape versions are not compatible with macOS Catalina. Good news: Inkscape is now a native application — no need for XQuartz.
If you decide to replace an earlier Inkscape version on your computer, remember to salvage the defaults.svg file you’re been using. Move it into the new application to save your preferred settings.
So I think the filleting is a visual clip and not actually a path modification. That’s disappointing. I’ll need to test it with the GF, but my guess is that the corners will be sharp even if filleted.
Yeah, right? The rounded corners extension is good though, if you’re dealing with straight lines. If you’re trying to fillet two curves you’re out of luck.
If like me your GF life depends on Tabbed Box Maker - I have been through the brain-bleeding process of getting the darn thing to work again. Needs testing, but I think I’ve got it.
Huh, that’s not how hershey used to work. You used to be able to just open hershey and type in your desired text and voila. I’ll try the new workflow and see.
So my fillet was set to 2mm radius and it was definitely too small. I measured the radius at .142 mm. It’s definitely not working correctly yet. Caveat emptor.
H[quote=“evansd2, post:14, topic:47038, full:true”]
[/quote]
I wonder if this is another stroke/geometry/visible issue where it is taking the width of the stroke into account?
- so OK if you only need a rounded edge then… Let me try it here, see if I get anything different. In the meantime I’ve lost my windows min/max/close buttons
Spot on for me!! It’s not that you’ve got % or px or something ticked by mistake?
