Hello.
I’m having problems with a circle outline that I want dashed in Inkscape where I used two circles and the “Exclude” in the paths tab to leave just the “Stroke,” I’ve tried turning the “Fill” off and leaving just the “Stroke,” and I’ve tried keeping the “Fill” and the “Stroke” but turning the opacity to zero, but nothing seems to work when I bring it into the GF UI. I keep getting the popup that says there’s dashes that it turned into lines. I’ve actually done this before on my very first real project I did, and it worked by selecting “Score” in the UI, but it’s not working with this circle. When I choose, “Engrave,” it burns the filled area, whether it’s filled or not, and “Score” turns it to solid lines.
Lastly, I keep getting popups that say text has been removed because they weren’t turned into paths, but I turned all of the text into paths, and from what I see, all of my text is still there.
Thanks in advance for any insight you might have on this. It’s driving me crazy since I’ve made an oval and changed it to dashes when I first got my GF and was able to use it under the “Score.”
