Sort of reviving an old closed topic.
I am trying to figure out how to get the living hinge into my Inkscape but is just NOT working for me. The following is a quote from another (now closed) thread on the same subject:
"The most important part of the instructions is:
Copy living_hinge.inx and src/living_hinge.py to your extension directory.
Don’t forget that src/ is actually a directory you’ll need to add to the existing extension directory. Put the python script in the new subdirectory. Here’s the relevant bit from the Inkscape directions:
Copy the files into the directory listed at Edit > Preferences > System: User extensions. After a restart of Inkscape, the new extension will be available.
Finding the right directory is typically the biggest challenge.
Good luck!"
“Copy the files into the directory listed at Edit > Preferences > System: User extensions. After a restart of Inkscape, the new extension will be available.”
So I’ve gotten to the :Edit > Preferences > System:" Do I “Open” the User Extensions?
Can someone please post a video of this because I’m totally lost.
