InkScape property settings for Glowforge
The biggest two things to do with inkscape is to get familiar with setting up a default template and installing a custom template.
You’ll use the default template (probably) to set up a page size of 19.5" by 10.9" (close enough to the laserable limits) which will help you in understanding placement and fitting parts on your workspace.
You’ll use the color palette to assist in setting up order operations.
(or, if you don’t like videos)
